Issue with qonto.com and OAuth2 callback
Error is generated when this redirect_uri returns from the qonto.com oauth2 flow. It happens when I add the credentials an click “Connect my account”. I can successfully authorize at qonto.com but n8n generates an error when qonto oatuh2 redirects to:
/rest/oauth2-credential/callback?code=xxxx&scope=&state=xxxxx%3D%3D
{“code”:0,“message”:“Client authentication failed (e.g., unknown client, no client authentication included, or unsupported authentication method).”}
  • n8n version: 0.221.2
  • Database you’re using (default: SQLite): SQLite
  • Running n8n with the execution process [own(default), main]:
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]: docker
Hey @DRone,
Welcome to the community :raised_hands:
Does Qonto support header as the authentication option, Looking at the docs quickly I think it is expecting Body.
That was literally the only parameter I never changed while doing try&error and I feel so stupid now :smiley: . Thanks so much
