I’ve been trying to set up n8n using Docker Compose by building my custom image, but I’ve encountered the error:
2025-01-06 17:59:18 env: can't execute 'node': No such file or directory
This error occurs when trying to run n8n after building the Docker image from a custom Dockerfile
located in the ./docker/images/n8n-custom/
folder.
My docker-compose.yml
Here’s the configuration I’m using:
services:
n8n:
build:
context: .
dockerfile: ./docker/images/n8n-custom/Dockerfile
container_name: n8n
ports:
- "5678:5678"
environment:
- DB_TYPE=mysqldb
- DB_MYSQLDB_HOST=mysql_db
- DB_MYSQLDB_PORT=3306
- DB_MYSQLDB_DATABASE=mysql_db
- DB_MYSQLDB_USER=root
- DB_MYSQLDB_PASSWORD=******
- N8N_PORT=5678
- N8N_BASIC_AUTH_ACTIVE=true
- N8N_BASIC_AUTH_USER=*****
- N8N_BASIC_AUTH_PASSWORD=*****
- WEBHOOK_URL=http://localhost:5678
- N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=false
volumes:
- n8n_data:/home/node/.n8n
restart: unless-stopped
depends_on:
mysql_db:
condition: service_healthy
mysql_db:
container_name: mysql_db
image: mysql/mysql-server:8.0
command: mysqld --character-set-server=utf8 --collation-server=utf8_unicode_ci
ports:
- "3306:3306"
volumes:
- mysql_data:/var/lib/mysql
environment:
MYSQL_DATABASE: mysql_db
MYSQL_ROOT_PASSWORD: ******
MYSQL_ROOT_HOST: "%"
healthcheck:
test: [ "CMD", "mysqladmin", "ping", "-h", "localhost" ]
interval: 10s
timeout: 5s
retries: 3
volumes:
n8n_data:
driver: local
mysql_data:
driver: local
The Error
When I build and run this Docker Compose setup, the n8n
container fails to execute the node
binary and throws the following error:
- n8n version: 1.73.1
- Database (default: SQLite): mysql
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Operating system: Windows 11
