Hello All,
I am trying to some text value from API call and formatting it in set node using expression. I can see the correct result in Result panel of expression but node is not returning any value. Attaching screenshots for reference.
Hello All,
Hi @Mustafa_Ali, the problem would be similar to what has happened here:
In short, .replaceAll() is supported by your browser (which is why it would be working in the preview), but not the Node.js version your n8n instance is using. Instead of using .replaceAll(), you could simply use .replace() and should get the desired result.
To replace multiple occurrences of <br /> using .replace() instead of .replaceAll() you could use .replace(/<br \/>/g, "").
