Hi I’m new here and migrating my workflows from make.com to N8N.
Import CURL command is not working properly.
When I use the CURL import on N8N it didn’t import it correctly, so I tweaked it to get an output in return.
CURL command in the Bright Data API documentation:
curl -v --insecure --compressed --proxy brd.superproxy.io:22225 --proxy-user brd-customer-<ACCOUNT_ID>-zone-: “pizza - Google Suche”
http request returning (correct) html data, supposed to be already parsed in JSON.
By adding “&lum_json=1” at the end of the url, the output should return json load, which isn’t.
When I remove this part, the output is not changing.
When I make the request through a python script, it’s working as expected and returning the parsed html output.
I’m using N8N cloud, calling Bright Data Serp API which supposed to return JSON data in a basic workflow
![Screenshot 2024-02-15 at 08.57.07|476x500]
“meta”: {
“instanceId”: “a2435d996b378e3a6fdef0468d70285e3aa0fbd0004de817bfc80e80afee4e7b”
“nodes”: [
“parameters”: {
“url”: “pizza - Google Suche”,
“sendHeaders”: true,
“headerParameters”: {
“parameters”: [
“name”: “Proxy-Authorization”,
“value”: “brd-customer-hl_<<<ID<>>-zone-serp:<<>>”
“name”: “Proxy”,
“value”: “http://brd.superproxy.io:XXXXX”
“options”: {
“allowUnauthorizedCerts”: true
“id”: “08c8d528-5926-4ca3-9e6c-a75e93335544”,
“name”: “HTTP Request”,
“typeVersion”: 4.1,
“position”: [
1320,
640
“alwaysOutputData”: true
“connections”: {},
“pinData”: {}
n8n version:
Version 1.27.2 -
Database (default: SQLite):
None -
Cloud
- Operating system:
