I’m having similar issues to Fails on automated execution but works manually - Questions - n8n and their workaround has been able to get me up and running.
I have a code node that converts the whenCreated time from an LDAP node into a new Date, when using this date within an If node it fails when executing the workflow with this error.
When executing the node manually it works correctly.
It seems to be changing the dateTime during the workflow execution, but not during individual node execution.
Like the above post I was able to work around using this expression
{{ new Date($json['created'].toString()).toISOString() }}
Has anyone else run into this? It’s tripped me up a few times now dealing with the various date formats that LDAP/AD seems to like to use.
NodeOperationError: The provided value 1 'Mon Jun 24 2019 12:22:41 GMT+0000 (Coordinated Universal Time)' in condition 1 is not of the expected type 'dateTime' [item 0]
at extractValue (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/ExtractValue.js:134:15)
at getNodeParameter (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/NodeExecuteFunctions.js:1451:54)
at Object.getNodeParameter (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/NodeExecuteFunctions.js:2090:24)
at /usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/If/V2/IfV2.node.js:68:33
at Array.forEach (<anonymous>)
at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/If/V2/IfV2.node.js:63:29)
at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:696:42)
at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:656:68
"dn": "snip",
"whenCreated": "20190624122241.0Z",
"userAccountControl": "snip",
"accountExpires": "snip",
"sAMAccountName": "snip",
"userPrincipalName": "snip",
"description": [],
"lastLogonTimestamp": null,
"enabled": true,
"lastLogon": null,
"formattedDate": null,
"created": "2019-06-24T12:22:41.000Z"
- n8n version: 1.21.1
- Database (default: SQLite): PostgreSQL 16
- Operating system: Ubuntu 22.04.3
