Issues with Pagination?
I am working on retrieving payment ledger items from Etsy and I’ve got stuck on what feels like the easiest part of the solution - pagination. I am using the HTTP node to try and paginate and it just fails to update the offset parameter, I’ve tried so many combinations:
  • Hard coding offset to prove it can be sent
  • Not including offset in the main query definition
  • Using the response length to try and stop pagination
  • Using “Empty” as the decider
Honestly, it just feels as though the pagination option is broken?
No error message but I can see 12 time windows being passed into the http block (one for each month) and a resulting set of 12 results from the node but all of them are limited to 100 with the count on the results showing many more than 100 available for each execution.
    "count": 57,
    "results": "[…] // 57 items"
    "count": 405,
    "results": "[…] // 100 items"
    "count": 823,
    "count": 1684,
    "count": 307,
    "count": 487,
    "count": 423,
    "count": 759,
    "count": 565,
    "count": 554,
  • **n8n version:**1.106.3
hello @jjbrunton
According to the docs, response object doesn’t contain the results property (in the complete expression of the pagination section).
Try this one:
{{ $response.body.results.length < $json.limit }}
