It is hard to post a complete post along with image via wordpress node..... Need Help! Please
Describe the problem/err
I find it difficult to use wordpress node to post a full text and image article on the wordpress website. I use merge node to transfer Title, Content and image to wordpress node, but it always fails, because I am a novice, not sure which one The steps are wrong, can you give me some advice?or/question
it successfully post the artical but no image…
  • n8n version: v1.31
  • Running n8n via (Docker, npm, n8n cloud, desktop app): AWS server, Railway
  • Operating system: Windows
Hi @ykh525050, are you trying to set a featured image? If so, check out this example from @martinhache on how to do so:
This would have to happen after you create the post itself. So a sequential workflow with the following steps should do:
  1. Create your blog post (without the image)
  2. Generate your image
  3. Upload your image
  4. Update your blog post to use the featured image from step 1
I don’t think this would need a merge node, but perhaps I have overlooked something. Give me a shout if you run into any trouble with this approach :slight_smile:
Thank you for kindly reply, I’ll try it.
