I have a simple workflow that executes a query in the BigQuery node and sends the contacts to one of two list IDs in Iterable.
The list ID can be either 2732100 or 2732102. However, after executing the workflow, no contacts have ended up on List 2732102. In fact no one ended up in the 2732102, its empty. There are 74 people from that query (minus the one invalid email), 43 should be going to list 2732100, and 31 should be going to 2732102. But 2732102 is completely empty and there’s only 70 people in 2732100. There are no duplicate email/list ID combos, I’m selecting distinct values from my query.
The one contact on list 2732102 was added manually by me using Iterable’s API via postman, so I know their API is working and the list ID is valid.
No errors thrown
- n8n version: Version 1.0.5
- Database (default: SQLite): Postgres
- n8n EXECUTIONS_PROCESS setting (default: own, main): Default
- Operating system: MacOS, but n8n is running in Linux VM
