Javascript help: changing an existing variable to another
Javascript help: changing an existing variable to another (variable name is “p_province” example is “Pennsylvania” to “us-pa”). I need to do this for each state. I’m relatively new to Javascript. Help!
Hi @cribbswh, welcome to the community!
Replacing text could be done using the JavaScript replace() method.
Seeing you want to do this for several different states I do, however, think it could make sense to define an array with all the names and codes you need, then write a little custom snippet looking up the respective code using the find() method instead. This will be much easier to edit in the future compared to several different replace methods.
Here’s an example workflow doing this for the format you have shared (us-pa):
Result:
Hope this helps!
