Hi,
Is it possible to use custom fields other than simple strings without making changes in the code? I’m asking for a situation where a custom field value is a list of objects for example.
The current code handling custom fields is:
const customFields = (additionalFields.customFieldsUi as IDataObject).customFieldsValues as IDataObject[];
if (customFields) {
const data = customFields.reduce((obj, value) => Object.assign(obj, { [`${value.fieldId}`]: value.fieldValue }), {});
Object.assign(fields, data);
I made a little change in the code to accept JSON string (with an additional boolean control in the custom field to toggle raw JSON string on/off) which then I can use templates (for example, using the value: [ { "name": "{{ $json.some_node_input }}" } ] ) but I’m not sure if I would need this. If anyone finds useful, I can submit a PR.
Thanks
PS: Thanks @jan for the correction of my original post location.
