Just FYI the Jira Trigger Node got released with [email protected]
Hi, apparently the Jira trigger does not work with the same credentials the “polling” does. Do polling and trigger require different permissions on Jira?
I am not sure I understand @baflo. What does the Jira Trigger node has to do with polling? It uses webhooks and works with the same credentials the regular Jira node uses.
@jan There are two Jira nodes: a trigger and a regular node. I referred to the regular node as “polling”.
The regular node works, but with the trigger node I get the error.
