jeanm
April 5, 2021, 11:07am
1
Hi,
The Jira node is failing on comments and attachment actions and the reason is that:
For Jira server there is no version 3 of the API;
For Jira server the comment body is not ADF format, but a simple string instead.
In essence, cloud vs server API differences.
I may try make a PR to help fix this, but wanted to gather feedback before (in case I’m doing something wrong:))
Thanks
Ahh yes. When we add new changes to the Jira node we are just able to test it on the Cloud version because we do not have a Server version. If you can send a PR would be awesome.
Hi,
I’m facing the same issue reported by @jeanm . I created this PR .
I also took the opportunity to fix the “user” actions which have been only implemented with API v3.
Welcome to the community @romainc
Thanks very much for your contribution. I just had a look and commented.
