Jira node's having problems with credentials
JIRA n8n nodes routinely show “Could not load list. Please check credentials” on all list dropdowns.
Every once in a while it works well and the list gets populated correctly.
Doing a “Test step” seems to increment the changes for it to work, but not enough to be sure.
Considerations:
  • It happens in all drop downs (ie. projects, issue types, fields).
  • Tested across several nodes and days.
  • If you by pass the list dropdown (ie. by going by ID), the actions works.
  • Chrome Developer tools you can see n8n endpoint returning a HTTP 500 Internal error
I’ve tested unsuccessfully:
  • Upgrade n8n
  • Rotate the credentials.
  • Give the credentials user jira admin rights.
in progress needs action
  • Configure JIRA credentials.
  • Test them.
  • Add a JIRA done like Update Issue.
  • Add a field to update.
  • Click “From list”
  • Open the dropdown.
This happens and workflow edit time.
  • Database (default: SQLite): Cloud
  • n8n EXECUTIONS_PROCESS setting (default: own, main): Cloud
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Cloud
  • Operating system: Cloud
n8n version: 1.81.4
Have you found a solution to this?
