Jira Project Selection
I am PM and using this is great to automate a lot of my reporting. However, I was wondering if anyone has figured out how to select only tickets for certain projects. Let me explain.
Below, is a screenshot of the Jira node where I am pulling all of the tickets. However, I only want to pull the ones for a certain projects. We have several different projects in our Jira and when I select “Return All” I get about 1600 tickets back. Does anyone know if this is possible via an expression?
Regards,
Oscar
@obeni welcome to the community.
Within options, there is a field called JQL (Jira Query Language), you can use this field to filter the issues by a certain project (and a lot of other stuff). More info about JQL can be found here. As you can see in the example below I’m filtering the issue by project name.
