I’m trying to combine a static metadata output with each item in a list of text chunks generated from a PDF. I want to send the combined result to an OpenAI node for summarization.
- The metadata is a single object (OpenAI completion).
- The chunks are generated dynamically using a
Code
node. - I want each chunk to include the same metadata.
I’ve tried using a Merge
node with Multiplex mode, and also attempted to do this in a Code
node, but the metadata keeps showing up as undefined inside the OpenAI prompt node.
No runtime errors, but metadata
is not appearing in the OpenAI node — it shows up red in expressions like {{ $json.metadata }}
even though it’s visible in the input of the previous node.
- n8n version: Version 1.98.1
- Database (default: SQLite): none
- Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud
- Operating system: windows 10
