Joining array values as a string
Hi there, I currently have this as an output:
    "allData": [
        "text": "Testing"
        "text": "Testing"
and I would like it to output
text: Testing, Testing
When I try
{{$json["allData"].join(', ')}}
all I get is:
[object Object], [object Object]
Any help is appreciated! Thanks!
Hey @djangelic, you’d need to join the text field rather than the full object. Here’s a quick example workflow doing this using the JS .map() method:
Example Workflow
Hope this helps! Give me a shout if you have any questions on this :slight_smile:
That works! However, I ended up using the Item list node to extract the array then call on the array values in the next node! Thanks for the help!
