JS help - Code returning "undefined" instead of object
Hello, I hope this is an appropriate question to ask in this forum. If not, please let me know.
I am trying to use the Code node, in conjunction with a form submission webhook node, plus the Google Workspace Admin node. This Code node is meant to check against the Google Workspace API, to see if a username is available. It goes through iterations of possible usernames, until it finds an available, valid one.
I really do not know enough about JavaScript to debug this. But I was hoping this community might be able to assist. I’m sure I’m missing something simple - like incorrectly mapping the JSON result from the previous (webhook) node.
Code snippet
async function main(node) {
  // First, let's define the variables we need to create a user
  const { firstName, lastName } = node.Tripetto.json.body;
  // Now let's define the main function that will check for available usernames
  async function findAvailableUsername() {
    let username = firstName[0] + lastName; // Try first initial + last name
    let searchResults = await node.GoogleWorkspace.searchUser({
      query: username,
      viewType: 'domain_public'
    if (searchResults.length === 0) {
      // If the username is available, return it
      return { username };
    } else {
      // If the first option is not available, try first name + last name
      username = firstName + lastName;
        query: username,
      } else {
        // If the second option is not available, try adding a number to the end of the last name
        let i = 1;
        while (true) {
          username = firstName + lastName + i;
            query: username,
          i++;
  // Finally, let's call the main function and return the result
  return findAvailableUsername();
Code doesn’t return an object (instead returning “undefined”)
Please share the workflow
    "headers": {
      "host": "n8n.example.tld",
      "content-length": "227",
      "accept": "application/json",
      "accept-encoding": "gzip, deflate",
      "content-type": "application/json",
      "x-forwarded-for": "127.0.0.1",
      "x-forwarded-host": "n8n.example.tld",
      "x-forwarded-proto": "https"
    "params": {},
    "query": {},
    "body": {
      "site": "string",
      "firstName": "text",
      "lastName": "text",
      "tripettoId": "00000000000000000000",
      "tripettoCreateDate": "2023-01-01T20:11:14.131Z",
      "tripettoFingerprint": "<fingerprint>"
  • n8n version: 0.209.4
  • Database you’re using (default: SQLite): SQLite
  • Running n8n with the execution process [own(default), main]: Default
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]: Docker
Thank you!
Welcome to the community @tmeuze !
Not at a computer right now but you do not return anything currently. You never call that main function. You would need at least something like
return main($input.first().json);
at the end.
Hello - thank you for your reply, and happy New Year!
In addition to what you said, I also realize that the method searchUser does not exist. I’m not quite sure how to determine what methods are available for this node.
To be fully transparent - I am aided by ChatGPT, which is helping me to build this functionality. I do hope that does not violate Community Rules.
Thank you, again.
PS - incredible software, n8n is.
