Hi,
I’m getting a json from an HTTP call and extracting some values from it to create a new json for a webhook response.
The webhook response is properly setup and works with some other code.
Right now I have a code module that takes the first json and transform it into an array. I tried to turn it in a json in various ways.
My closest solution (below) so far seems good… But a bracket is added at the end of the input item when I try to use it in the webhook response.
I feel stuck right now and can’t seem to figure it out. What am I doing wrong? Or is there a bug?
The ideal webhook response would look like:
"id": "0a61l",
"block": "form",
"inputs": [
"type": "select",
"name": "A select",
"label": "Owner",
"selectValues": [
"name": "My first value",
"value": "my-first-value"
"name": "My second value",
"value": "my-second-value"
"name": "07q6h96c0671vjq4",
"value": "07q6h96c0671vjq4"
"name": "tw5947pt1fop5t",
"value": "tw5947pt1fop5t"
"name": "vb5qtk37fmk31v1u",
"value": "vb5qtk37fmk31v1u"
"name": "eyuzd4nv34e17db2",
"value": "eyuzd4nv34e17db2"
"name": "osg53hexfy1w9n1",
"value": "osg53hexfy1w9n1"
"name": "poz1nrd1pe1a7b9",
"value": "poz1nrd1pe1a7b9"
"name": "8h21271ae2ed9",
"value": "8h21271ae2ed9"
"name": "mu1g5xfrormjllg",
"value": "mu1g5xfrormjllg"
"name": "y6hyevbo8j960y2l",
"value": "y6hyevbo8j960y2l"
"name": "v6xp3tatg419jom",
"value": "v6xp3tatg419jom"
"name": "yl7vowutfypcor",
"value": "yl7vowutfypcor"
"actionButton": {
"name": "My Button",
"label": "My Action Button",
"style": "secondary"
"url": "http://callback.url.com"
“ERROR: Invalid JSON in ‘Response Body’ field
Check that the syntax of the JSON in the ‘Response Body’ parameter is valid”
(and that’s about right!)
The json body is incorrect because I have one bracket too many here :
“value”: “yl7vowutfypcor”}}] (code below)
What’s weird is that the json from the last scenario seems fine when I look at it from the left side panel… But using {{ $json.inputs }} seems to add a } for some reason.
Here is the output of the last node before the webhook response:
"id": "elmjw149",
"block": "form",
"inputs": [
"type": "select",
"name": "A select",
"label": "Owner",
"selectValues": [
"actionButton": {
And “output” (what I see in the Response Body module):
"id": "0a61l",
"block": "form",
"inputs": [{"type": "select", "name": "A select", "label": "Owner", "selectValues": [{"name": "My first value", "value": "my-first-value"},{"name": "My second value", "value": "my-second-value"},{"name": "07q6h96c0671vjq4", "value": "07q6h96c0671vjq4"},{"name": "tw5947pt1fop5t", "value": "tw5947pt1fop5t"},{"name": "vb5qtk37fmk31v1u", "value": "vb5qtk37fmk31v1u"},{"name": "eyuzd4nv34e17db2", "value": "eyuzd4nv34e17db2"},{"name": "osg53hexfy1w9n1", "value": "osg53hexfy1w9n1"},{"name": "poz1nrd1pe1a7b9", "value": "poz1nrd1pe1a7b9"},{"name": "8h21271ae2ed9", "value": "8h21271ae2ed9"},{"name": "mu1g5xfrormjllg", "value": "mu1g5xfrormjllg"},{"name": "y6hyevbo8j960y2l", "value": "y6hyevbo8j960y2l"},{"name": "v6xp3tatg419jom", "value": "v6xp3tatg419jom"},{"name": "yl7vowutfypcor", "value": "yl7vowutfypcor"}}]
"actionButton": {
- n8n version: Cloud, so last I guess
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): Unsure
- Running n8n via (Docker, npm, n8n cloud, desktop app): Cloud
- Operating system: Not relevant… but windows
Please let me know if something else is needed to solve this.
