JSON output from python CODE node does not include null fields
I am using a CODE (python) to transform data produced upstream in my workflow into a somewhat complex JSON format. The JSON schema has a bunch of required fields that must be set to null because my workflow is not supposed to produce that data.
PROBLEM: as I create a python dict that complies with the expected JSON schema I diligently set to None all the fields that must have a null value.
However, when I send it out of the CODE node as output this way:
return [ final_json_dict ]
I see that the node output does not include any of the null fields
No error message
  • **n8n version: 1.77.3 **
  • **Database None **
  • **n8n EXECUTIONS_PROCESS setting: v1 **
  • Running n8n via Cloud
  • Operating system: Mac
Seems so. use the javascript in that case, or populate the nullish fields with the Edit Fields node
@barn4k Thanks for the advice.
I would like to avoid maintaining and expanding javascript code since I am not really proficient with it.
Do you have an example of what you mean with:
populate the bullish fields with the Edit Fields node
like this
