Hi guys.
How do combinate Loop Over Items with a json response contais cursor header ?
json header:
“size”: 2,
“limit”: 10,
“total”: 2,
“data”: […
When a try execute my flow de loop just find one registre, this registre is all json file…
Hi guys.
json header:
“size”: 2,
“limit”: 10,
“total”: 2,
“data”: […
Welcome to the community @Silvio_Brito
Not sure if I understand your question here, could you tell me a bit more about what you’re trying to achieve with the workflow, or share your workflow by copy & pasting the workflow JSON content (or parts of it) in between two block quotes (```)
hi, ok. Let me explain
Json file:
"size": 2,
"limit": 10,
"total": 2,
"data": [
"id": "3458764592550886426",
"type": "sticky_note",
"data": {
"content": "<p>US - Titulo US</p><p><br /></p><p>Descrição: Descrição US</p>",
"shape": "square"
"style": {
"fillColor": "light_yellow",
"textAlign": "center",
"textAlignVertical": "middle"
"geometry": {
"width": 604.6931417145194,
"height": 692.8142528186453
"position": {
"x": -143.46997784741546,
"y": 866.8388124866581,
"origin": "center",
"relativeTo": "canvas_center"
"links": {
"self": "https://api.miro.com/v2/boards/uXjVK6xJV7Q%3D/sticky_notes/3458764592550886426"
"createdAt": "2024-06-18T14:11:37Z",
"createdBy": {
"id": "3074457359533130449",
"type": "user"
"modifiedAt": "2024-06-18T19:32:57Z",
"modifiedBy": {
"type": "user"
"id": "3458764592588857410",
"data": {
"content": "<p>US - Login de usuário</p><p><br /></p><p>Descrição: Como usuário do aplicativo, quero poder inserir meu usuário e senha do aplicativo na tela home a fim de poder logar na aplicação.</p>",
"shape": "square"
"style": {
"geometry": {
"position": {
"x": -997.2138776258422,
"y": 866.838812486658,
"origin": "center",
"links": {
"self": "https://api.miro.com/v2/boards/uXjVK6xJV7Q%3D/sticky_notes/3458764592588857410"
"createdAt": "2024-06-18T20:28:43Z",
"createdBy": {
"type": "user"
"modifiedAt": "2024-06-18T20:29:17Z",
"modifiedBy": {
"type": "user"
"links": {
"self": "https://api.miro.com/v2/boards/uXjVK6xJV7Q%3D/items?limit=10&cursor="
"type": "cursor-list"
Flow: I just need iterate de json, but because this code intial code the loop indentufy only one regitre.
Hi @Silvio_Brito thanks for sharing your workflow and the json output which looks like a paginated response from the Miro API listing sticky notes within a board. If you want to split out the json output into separate items, one for each sticky note, you can use the Split Out node:
Is this what you were looking for?
Hello, thank you for your reply. I was able to resume this project.
The split node worked perfectly. Thank you.
Now I have another problem, because this API uses cursor pagination. I saw the pagination option in the HTTP node but I didn’t understand how to use a cursor that comes inside the API’s json return.
