I was manually running and editing large workflows with no issue and then suddenly everything starts lagging.
The spinning symbol over a node keeps getting stuck on a node even though i can see in the background its continued to run future nodes ( i can see files appearing in my google drive so I know they are running ahead of where indicated)
Sometimes 2 nodes will have the spinning node at the same time. It finishes running ( I can see the last update on a file in the background) but the workflow is still stuck way back at the beginning. It then never shows it completing on the screen but if i force a stop it says its finished before it could be stopped!
This is the same regardless of which workflow I run, i have just create a very simple small workflow and its the same.
Help! What can I do to get it back to how it was before which was fantastic!?
I have restarted the service several times with no change. Restarted my browser and same again. Tried on different browser type, same again.
Iām on latest version 1.121.3
Can anyone help?
Thanks
