here is the wrokflow i tried to built and im stuck.
im trying to built an agent that when i upload contract to drive he scan the file and also has already scan a folder with the contracts i have - the result will be that he will tell me base on the previous contracts what are the problems in this new contract ? how to imporve it etc.
you must connect your google drive trigger node to search file node, also you don’t need another Merge in your search file function
connected it but the result i got with the txt file in the drive folder - isnt that perfect. how can i make it better ?
Why do you need loop over item node btw? you can remove it too.
Also, what is your expectation with the file output?
