Level 2 > Workflow 2 > Unique ID error
Hello,
I get this error in the HTTP request node. I don’t understand what’s wrong with my unique ID.
I copied / pasted the one I received by email (just replace some letters by * when I shot my screen).
When I try using unique id from other users (found on discord), it doesn’t work neither.
I used the Header Auth name and Header Auth value for Header Auth.
Any idea ?
Hey @Jayjay,
Can you try it now and let me know how you get on?
Hello @Jon,
Unfortunately now I get a 500 error.
Capture d’écran 2023-11-14 à 20.21.37
Hey @Jayjay,
Ah I may have broken something else, I will fix it in the morning.
Hey @Jayjay,
I have made a quick change to the workflow that runs to get the data and even given it a test this time and you should be good to go :slight_smile:
Finally it’s working !
Thank you :slight_smile:
Capture d’écran 2023-11-15 à 12.57.18
