LinkedIn OAuth Works in Postman but Fails in n8n – “invalid_request” Error (Need Help)
I’m facing an issue while connecting LinkedIn OAuth with n8n, and I’m hoping someone here can point me in the right direction.
Here’s the situation:
  • I have created a custom LinkedIn app
  • The app is fully verified
  • OAuth flow works perfectly in Postman
  • Access token is generated successfully outside n8n
However, when I enter the same client ID, client secret, and redirect URI in n8n, the LinkedIn account connection fails.
I keep getting this error:
  "error": "invalid_request",
  "error_description": "Unable to retrieve access token: appid/redirect uri/code verifier does not match authorization code. Or authorization code expired. Or external member binding exists"
Things I’ve already checked:
  • Redirect URI matches (as per LinkedIn app settings)
  • App credentials are correct
  • App permissions/scopes are approved
  • OAuth works fine via Postman
It feels like something specific to n8n’s OAuth implementation (PKCE / redirect handling / cached auth?) but I’m not able to pinpoint it.
Has anyone:
  • Successfully connected a custom LinkedIn app with n8n?
  • Faced this exact error before?
  • Found a workaround or configuration fix?
Any guidance, docs, or practical tips would be highly appreciated :folded_hands:
Thanks in advance — really looking forward to resolving this.
Have you checked that you’re running the latest version of n8n?
There was a bug with OAuth that got fixed with version 2.1.3:
@saimansolutions
Thanks for the suggestion let me try it
