Linkedin Scraper old Data to New Data I Need Help
I’ve created an N8N workflow that scrapes data from LinkedIn. Now, I want to integrate this workflow into a React.js or Next.js application, preferably through the backend. I’m struggling with how to connect the N8N workflow to my app. Can you guide me on how to do this properly?
If there isn’t a database between n8n and your app.
The most likely you will create a webhook trigger in n8n.
And your React app will call the webhook url as an API to get data from n8n.
I really admire your answer. I tried creating a webhook trigger in n8n and set up my React app to call the webhook URL as an API to retrieve data. However, the workflow didn’t run automatically as expected. Could you help me understand why it’s not working?
Like Self Hosting other else I Dont know
