I run a workflow to make a new user in a system.
Early step is checking if user is already in system, preferably by trying to get their data.
API returns 404
404 - {"error":{"code":404,"message":"Resource Not Found: userKey","errors":[{"message":"Resource Not Found: userKey","domain":"global","reason":"notFound"}]}} - Resource Not Found: userKey
I would like to be able to load those details into IF node. Instead, all I get is an error that the previous node failed.
Error running node âGoogle Workspace Adminâ
âContinue on Failâ
âAlways output dataâ
donât resolve the issue
- n8n version: 1.8.2 cloud
- Database (default: SQLite):
- Operating system:
