Hello,
I can’t find the company in Hubspot
Goes to false since it can’t find the company in the CRM.
I’m giving the search node 15 minutes before executing to ensure that the creation has been made.
Since hubspot it works as follow :
If a contact has been created, so a company will be created automatically with the domain name.
So the node should have enough time to create contact + company and when it comes to search it should return for me the company.
Above there is a test workflow : When I run it statically now the node find the company, the issue is only during the workflow
Any thoughts ?
- **Running n8n via : n8n cloud
