Loop node executes 'DONE' branch before 'LOOP' branch?
ScreenRecording2025-02-09at22.52.59-ezgif.com-video-to-gif-converter
Loop over Items executes the items in this order:
  1. DONE branch with the ‘split out’ data
  2. Loop branch #1
  3. DONE branch with #1 data
  4. LOOP branch #2
  5. DONE branch with #2 data
and so on
What is the expected flow?
Finish the loops, then execute the DONE branch with the aggregated JSON from all the loops results
I’m on the n8n cloud env.
Anyone else able to make sure the ‘Done’ branch is run only after all the loops are executed?
I have the same issue. Did not found a solution so far :frowning:
