My workflow contains Loop over, the input is json array, each item in the array is array of urls. I need loop through json array. The flow seems to work but Loop node never finishes/ outputs anything in done. I do not see any errors. am I missing something?
Thank you
No errors
n8n version:
cloud
Database (default: SQLite):
Default
default
cloud and local
Operating system:
local Linuxmint 22.2
n8n
June 21, 2024, 8:02am
2
n8n version:
Operating system:
ria
June 21, 2024, 3:10pm
3
Hi @AIEnthusiast
Thanks for posting here and welcome to the community!
Which n8n version are you on? I executed your workflow and all worked well for me
Hi @ria , you are right it does, I needed to run Set node in order to get doing the all cycles, running Merge1 node was not enough, i thought it was.
Thank you
system
Closed
September 22, 2024, 4:11pm
6
