Loop Over Items does not loop through all items (Firebase → Notion)
I am building a very simple workflow that should sync data from Firebase to a Notion database.
  1. A Firebase node retrieves a list of agents.
  2. A “flatten” Code node converts the result into a list of items like this:
json
[ { "agentName": "Agent A (Group)", "agentRef": "id_001", "lastSync": "2025-12-05T15:26:48.626146Z", "nbCompanies": 2 }, { "agentName": "Agent B (Group)", "agentRef": "id_002", "lastSync": "2025-09-22T10:08:44.238688Z", "nbCompanies": 4 }, { "agentName": "Agent C (Group)", "agentRef": "id_003", "lastSync": "2024-12-14T14:37:27.784322Z", "nbCompanies": 18 } // etc. (9 items in total)]
  1. The Loop Over Items (Split in Batches) node receives all 9 items as input.
  2. For each item, I do:
    • Notion - Query on a “Id” field where**{{$json.agentRef}}matches**
    • IF - Exists?
      • trueNotion - Update Page
      • falseNotion - Create Page
Goal: for each item in the list, create or update a Notion page with the agentName, agentRef, lastSync, and nbCompanies properties.​
Problem
The Loop Over Items node does not process all items passed to it.
In the logs:
  • The node right before the Loop shows 9 items.
  • The Loop starts, but only the first page is updated in Notion, then the execution finishes as if everything were done (no error).​
What I have already checked
  • The “flatten” Code node really returns 9 separate items (not a single item containing an array).​
  • In the Loop, the batch size is set to 1 and the “loop” connection goes back into the Loop Over Items node.​
  • The Notion nodes work correctly when tested with a single item.​
Questions
  1. Am I using the Loop Over Items (Split in Batches) node correctly in this scenario?
  2. What could cause the loop to stop before processing all 9 items when there is no error in the execution?
None
  • n8n version: 2.0.3
  • Database (default: SQLite):d default
  • n8n EXECUTIONS_PROCESS setting (default: own, main): Default
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Hostinger
  • Operating system: VPS
Hi @ThiTou,
Why do you have two Loop nodes? You’re essentially creating a nested loop which can cause confusion and issues if the data is simple enough.
However, in your second loop node, rather set the batch to 1 so you loop over 1 item at a time.
For example this flow will serve you better as you can see the loop iterated over each item of the 3 items in the example trying to find one item at a time to compare, update or create
Indeed. It makes a lot more sense to me know.
I didn’t mean to keep the double loop in the workflow though .
I tried to loop over agents and then for each agent loop over the companies listed in each agent collection originally but I stripped it down as the double loop created issues.
Thanks @Wouter_Nigrini !
That is great news! Shout if you need any further help
