Loop Over Items node stops workflow execution after completion
Hi everyone,
I’m encountering an issue with the Loop Over Items node in my workflow. After processing all items through a loop, the workflow execution stops completely instead of continuing to the next nodes.
My workflow structure:
  1. Data comes into Loop Over Items node (batch size: 500)
  2. Loop Over Items splits to:
  • SG HTTP Request node for processing
  • Aggregate node to collect results
  1. SG HTTP Request results feed back into the Loop Over Items node
Current node settings:
  • Loop Over Items has retryOnFail: true
  • alwaysOutputData is set to true
  • Aggregate node is set to aggregateAllItemData
Expected behavior: After processing all items, the workflow should continue to subsequent nodes (Convert to JSON and OneDrive upload nodes) Actual behavior: The workflow stops completely after the loop finishes processing all items
I’ve tried:
  • Setting alwaysOutputData to true
  • Verifying all connections are correct
  • Checking for errors in execution logs
Is there something I’m missing in the configuration?
