A Webhook to receive incoming event log. Item lists split the each log in the message body. I want to get notified when Loop Over items has error so I enable Continue(using error output).
Loop Over Items can see incoming data but it doesn’t pass to “Insert MySQL” when “On Error” is set to “Continue(using error output).” It can pass the data to “Insert MySQL” when “On Error” is set to “Stop Workflow” or “Continue”
Webhook → Item lists-> Loop Over Items → Insert MySQL
Loop Over Items stopped when there is Continue(using error output) configured.
Loop Over Items works when there is no Continue(using error output) configured.
- n8n version: 1.18.2
- Database (default: SQLite):
- Operating system:
