Hi, I have a problem with n8n. I don’t understand why my loop is not completing entirely. I have 65 items that should loop, but after 3 items, the workflow crashes.
Hi @delcros_w ![]()
You didn’t mention if you’re self-hosting n8n, or if you’re on n8n cloud - if you’re self-hosting, could you provide some server logs? I have a hunch that you may be running out of memory, but without logs it’s hard to say what’s going on.
It is stopping at nr 2 in the below image, you see it just stops there. If it is actually crashing it will be because of a memory issue probably. If it just stops it will be because this code node isnt returning any data and thats why the path doesnt continue there.
