I am new to n8n and Lovable UI. I have super basic understanding of software engineering. This is for a capstone project as product managers.
My task flow is to upload an image of a room, use AI to detect individual objects in the room, pull some popular design styles eg Modern, minimalist etc. I wan to user to receive the objects and styles so they can choose one. But the image url to be used downstream. I have a webhook to start the uploading of image and generate all the outputs I have mentioned. I can see them in the respond to webhook. But Lovable is not showing these objects and styles. it is receiving the response but I cannot tell why it is not rendering properly on UI. I have tried everything I can.
There is no error message in n8n. It skist that the next webhook doesn’t fire up because user has to have selected an object and a style. But they cannot see them to select. So I am stuck there.
I have removed credentials:
"objects": [
"id": "object_1",
"label": "Beige Sofa",
"description": "A large, light beige sofa with two matching cushions located at the top center of the room."
"id": "object_2",
"label": "Taupe Sofa",
"description": "A slightly larger, textured taupe-colored sofa with grey and cream pillows situated on the left side of the room."
"id": "object_3",
"label": "Area Rug",
"description": "A large, cream-colored rug with embossed geometric diamond patterns covering the central floor area."
"id": "object_4",
"label": "Wood Table Lamp",
"description": "A medium-sized table lamp with a cream shade and wooden base placed on a side table next to the taupe sofa on the left."
"id": "object_5",
"label": "Floor Lamp",
"description": "A tall, white-shaded floor lamp with a slender stand located at the far right of the room."
"id": "object_6",
"label": "Round Woven Ottoman",
"description": "A small, round, off-white woven ottoman with a lid, placed near the right side of the beige sofa."
"id": "object_7",
"label": "Throw Pillows",
"description": "Multiple small throw pillows in beige, cream, and grey tones placed on both sofas, contributing to the room’s soft color palette."
"id": "object_8",
"label": "Curtain Set",
"description": "Thick beige curtains paired with sheer white ones positioned behind the beige sofa, framing the window (considered decorative)."
"id": "object_9",
"label": "Blanket",
"description": "A light grey, patterned throw blanket draped over the arm of the taupe sofa on the left side."
"id": "object_10",
"label": "Decorative Logs and Tools",
"description": "A small set of decorative fire tools and stacked logs in a holder located on the far right, near the floor lamp and ottoman."
"styles": [
"id": "scandinavian",
"label": "Scandinavian",
"value": "Scandinavian",
"description": "Scandinavian style furniture and decor"
"id": "traditional",
"label": "Traditional",
"value": "Traditional",
"description": "Traditional style furniture and decor"
"id": "minimalist",
"label": "Minimalist",
"value": "Minimalist",
"description": "Minimalist style furniture and decor"
"id": "rustic",
"label": "Rustic",
"value": "Rustic",
"description": "Rustic style furniture and decor"
"id": "contemporary",
"label": "Contemporary",
"value": "Contemporary",
"description": "Contemporary style furniture and decor"
"id": "industrial",
"label": "Industrial",
"value": "Industrial",
"description": "Industrial style furniture and decor"
"id": "bohemian",
"label": "Bohemian",
"value": "Bohemian",
"description": "Bohemian style furniture and decor"
"image_url": "https://ik.imagekit.io/evmsruyjl/ready-mage__gEeewPSB.png"
- n8n version: [email protected]
- Database (default: SQLite):
- Running n8n via (Docker, npm, n8n cloud, desktop app): Cloud
- Operating system: MacOS Sequoia 15.4
