Magic Inbox is a custom extension for n8n that allows you to teleport workflows, messages, or files instantly between n8n instances—using webhooks as pure peer-to-peer, with no centralized server.
Not just for private transfer, Magic Inbox also brings “forum-style” group channels, making teamwork and community sharing frictionless.
What is Magic Inbox?
Magic Inbox lets you:
- Instantly teleport (import/export) n8n workflows between friends, servers, or teams
- Chat, share files or create collective flows across open or private channels (“forums”)
- Control exactly what you accept and from whom, thanks to sender allowlisting and message type filtering
- Use various messaging modes: P2P, team forum, or custom group endpoints
Features Overview
Teleportation:
- Send and receive workflows (and their content) to/from any n8n, as easily as sending a message—true “teleportation”, with optional auto-import
Forum Channels:
- Set up community or project channels (e.g. /chat/general, /chat/help, /chat/inspiration) where many users can exchange messages and teleport workflows
- Each forum node listens on its own path, keeping group content organized and separated
Custom Group Inboxes:
- Need a private team space? Just set a custom path (e.g. /chat/my-team-lab) for your group
Security & Filters:
- Allowlist (whitelist) senders to restrict who can post/teleport to your inbox
- Filter accepted types (chat, workflow, file) per node
- All exchanges encrypted via HTTPS
Auto-import:
- Instantly import a workflow into your n8n on reception (if enabled), using your own API key and instance URL
- Never shares your API key or credentials! Import only runs locally and if you enable it
Open & Flexible:
- 100% webhook-based: no cloud, no middleware, works on-prem, behind VPN, on any server or PC
- Docs, UI hints, and parameters fully described for every user
Main Parameters
- inboxMode: Choose P2P, forum or custom group
- forumRoom: The forum/channel path (if forum mode)
- customRoomPath: Custom path (for custom modes)
- acceptedTypes: Accept only chat, workflows, or files
- allowlist: Enter allowed sender IDs (emails, aliases)
- autoImport: Enable if you want workflows to import on-the-fly (needs n8n URL + API key)
- addressBook: Personal directory of favorite endpoints or collaborators
Usage & Scenarios
1. Private P2P Teleportation
Set up a Magic Inbox node with mode: p2p.
Share your webhook URL (e.g. /magic-inbox).
Any contact with MagicInboxSend can teleport you a workflow/message/file directly.
2. Forum Channel Collaboration
Create a Magic Inbox node with mode: forum.
Pick a room (e.g. /chat/general).
Anyone with the endpoint can post/teleport content.
Works like a Slack/Discord channel, but P2P and decentralized!
3. Custom Team/Project
Set mode to custom, define a path (e.g. /chat/growth-hackers).
Only share with your team—get a private group chat with built-in workflow teleportation.
4. Receive and “Auto-Teleport” Workflows
Activate auto-import, fill your instance URL and API key.
Every workflow teleported (and accepted) is instantly cloned/imported in your n8n — real magic!
Sending (Teleporting)
Use MagicInboxSend node:
- Destination: any MagicInbox webhook (user, forum, group)
- Set your public ID, message, type of content, and attach workflows or files as needed
- The “teleportation” happens as soon as the peer node receives it!
Installation
Install via npm:
npm install n8n-nodes-magic-inbox
Or copy the node directory to: ~/.n8n/custom/nodes/ and restart n8n.
Security Model
- No server in the middle: all peer-to-peer, via HTTPS
- Allowlist: block all senders except those you trust
- Auto-import only runs if enabled and with your local credentials
- All forum/group channels are just paths : you decide who shares/teleports there
Good Practice Tips
- Use a forum node per channel group to keep flows sorted
- Protect your inbox URLs (don’t broadcast public unless you intend open forum)
- Have descriptive sender IDs for tracking
- Combine with team chat tools (Telegram, Slack) as you wish—Magic Inbox is compatible
Example: Use-Cases
- Instantly teleport a critical workflow from staging to production n8n via P2P
- Set up a “General” or “Jobs” forum and invite many users to exchange workflows without admin
- Use a custom team inbox for a temporary project, then delete it for privacy
Credits
Made by Charles Lepoittevin, 2025 (Montpellier, Occitanie)
Contact: charleslepoittevin34@gmail.com
Inspired by blockchain, P2P, and the dream of instant, human-friendly automation sharing.
Magic Inbox is minimal.
It teleports your workflows and builds real community.
It’s yours—and it’s magic.
