Mailerlite connection problem
Hi, I can’t connect Mailerlite to n8n. When I tried to click on “Listen For Event”, an error message appears:
Capture d’écran 2023-04-27 à 10.31.21
Someone knows what’s the problem?
Hey @caro,
Welcome to the community :cake\
What version of n8n are you using, Which Event option do you have set and is your webhook url displaying localhost still?
Thank you @Jon ! :blush:
I’m using version 0.225.2. I set the event “Subscriber added to a group”. How can we verify if the webhook url is still displaying localhost?
Hey @caro,
In the node at the top it will say webhook urls, if you click on that it should tell you.
If it does say localhost you will need to set the WEBHOOK_URL environment option to match your domain.
