Hi guys,
I was using the HTTP Request node with Basic Auth to make an internal comment on a Jira issue and that was working fine.
The problem now is that Attlasian deprecated the Basic Auth and I can no longer use the HTTP Request node to make that internal comment so I tried using the Jira node.
The problem here is, how can I say that this comment is internal on the issue using the Jira node?
This was the working internal comment in HTTP Request node
