Max body/text length
Hello,
Before i start messing around with function nodes, Is there a way to have a max text length as an expression?
and, (I wasnt sure i should’ve created a new thread for this)
Is there a way to do this with any kind of text?
Since i just need the Text, Not the HTML
Hey,
Sorry but I am not sure what exactly you want to do. Can you please provide a bit more detail?
Thanks
I got a string of html with text in it, I just need the text
For the max length i figured out i can do this
{{$node["IF"].json["Body"].slice(0, 75)}}
You’ll have to enter a CSS selector in the CSS Selector field. This can be a class (append with a ‘.’), an id (append with ‘#’) or an HTML tag.
The Key field sets the key for the value that will be returned. For example, if you’re extracting links, your key can be Link and the CSS selector can be a (for the anchor tag).
Below is an example workflow that returns text that is wrapped by the HTML tag containing the class link-primary.
I hope this helps :slightly_smiling_face:
I got it to work :wink: Had to figure out i needed put something else in then “data”
That’s great! Have fun :slightly_smiling_face:
