MCPClientNode does not include Authorization header despite Bearer token configured
I’m using the MCPClientNode in n8n v1.95.3 and configured it with Bearer Token authentication. However, the outgoing HTTP request does not include the Authorization header at all.
I confirmed this by checking the request headers via a custom Cloudflare Worker that logs incoming requests — and the Authorization header is completely missing.
I also tried sending the same request using the regular HTTP Request node, and it includes the Authorization header as expected. So the issue seems specific to the MCPClientNode.
Is this a known bug? Or is there some additional configuration required to make it send the header?
  • n8n version: 1.95.3
  • Running via: Docker (local setup)
  • OS: Windows 11 with WSL2
