I have an issue where the merge node returns no data if the input from Input 1 is empty. My understanding is it should still show the data from input 2?
If that is not the case, how does one then handle merges when input 1 may or may not contain data?
Hey @Robm, the Merge node would not run if it doesn’t receive an item on input 1 I am afraid. As a simple workaround, you could enable the Always Output Data option on the previous node (which would mean an empty item is sent to the Merge node):
You could then place an IF node after your Merge node to keep only the items you’re interested in (and thus filter out the empty item).
