MERGE node: Combine mode does not work as expected
The MERGE node with the Combine By Position does not work as expected.
Instead of combining the two inputs, it merely outputs the Input1 of the node.
The error picture is such:
INPUT1:
“output”: “DO-NOTHING”
“output”: “FORWARDING”
INPUT2:
“from”: ""ClickUp Team" ",
“subject”: “Access GPT-4o, o1, and o3-mini in ClickUp—Half the Price”,
“attachment”: “false”,
“textPlain”: “MSG_BODY_1”
“from”: "AlphaSignal ",
“subject”: “:loud_sound: OpenAI Releases Speech Model APIs: Real-Time AI Voices & Transcription”,
“textPlain”: “MSG_BODY_2”
“subject”: “Try automatic scheduling”,
“textPlain”: “MSG_BODY_3”
“from”: "Ulf Morys ",
“subject”: “Bittte morgen auf jeden Fall anrufen”,
“textPlain”: “MSG_BODY_4”
“from”: "Medium ",
“subject”: “Samir Issa added your story A practical n8n workflow example from A to Z — Part 1: Use Case, Learning Journey and Setup to their list AI”,
“textPlain”: “MSG_BODY_5”
I “just” want to join the “output” info from INPUT1 to each item in INPUT2 by position. In other workflows (but with different hosting) this worked fine by simply using the MERGE node and “combine by position”.
However, the output from the MERGE node is invariably simply the INPUT1, aka:
None, just an unexpected output.
  • n8n version: 1.83.2
    environment:
    DB_TYPE: postgresdb
    DB_POSTGRESDB_HOST: postgres
    DB_POSTGRESDB_PORT: 5432
    DB_POSTGRESDB_DATABASE: ${POSTGRES_DB}
    DB_POSTGRESDB_USER: ${POSTGRES_USER}
    DB_POSTGRESDB_PASSWORD: ${SOFTWARE_PASSWORD}
    EXECUTIONS_MODE: queue
    QUEUE_BULL_REDIS_HOST: redis
    QUEUE_HEALTH_CHECK_ACTIVE: “true”
    WEBHOOK_TUNNEL_URL: https://${DOMAIN}
    WEBHOOK_URL: https://${DOMAIN}
    N8N_BASIC_AUTH_ACTIVE: “true”
    N8N_BASIC_AUTH_USER: ${N8N_BASIC_AUTH_USER}
    N8N_BASIC_AUTH_PASSWORD: ${SOFTWARE_PASSWORD}
    N8N_HOST: ${DOMAIN}
    N8N_EMAIL_MODE: “smtp”
    N8N_SMTP_HOST: ${SMTP_HOST}
    N8N_SMTP_PORT: ${SMTP_PORT}
    N8N_SMTP_USER: " "
    N8N_SMTP_PASS: " "
    N8N_SMTP_SENDER: ${SMTP_FROM_EMAIL}
    N8N_SMTP_SSL: “false”
    NODE_TLS_REJECT_UNAUTHORIZED: 0
    EXECUTIONS_DATA_PRUNE: ${EXECUTIONS_DATA_PRUNE}
    EXECUTIONS_DATA_MAX_AGE: ${EXECUTIONS_DATA_MAX_AGE}
    N8N_ENCRYPTION_KEY: ${N8N_ENCRYPTION_KEY}
    N8N_DEFAULT_BINARY_DATA_MODE: filesystem
    N8N_PAYLOAD_SIZE_MAX: 32
    N8N_COMMUNITY_PACKAGES_ALLOW_TOOL_USAGE: “true”
    links:
    • postgres
    • redis
  • Running n8n via (Docker, npm, n8n cloud, desktop app):: Running in elest.io instance
  • Operating system: Managed service… very probably some kind of Linux
Hello @syrom welcome to the community :tada:
could you give combine by all possible combinations a try?
That was quick ! Will try tomorrow. It’s almost midnight and I’m about to loose my Duolingo streak :wink:
:smiley: no problem, you have to feed the bird :joy:
Negativ, still the same result.
As you can see from the screenshot below, the node receives two “correct” inputs, INPUT1 and INPUT2, but the output is again equal to INPUT1.
Can you please check if the Merge_Classification_with_Content is activated? Cause in your shared workflow it’s deactivated.
I just checked the execution and it works great.
Changed Combine By to All Possible Combination as @mohamed3nan suggested.
Thx Franz !
Yes, I ran the WF manually, while it was not activated. But also activating the WF didn’t change anything in the behviour. At the risk of revealing my newbie status: I am unaware how I could activate or deactivate a single node. So I suppose your question related to having the WF activated, correct ?
Later this day, I will test the workflow on a local docker install. I somehow have the guts feeling that this will work (like for you) - and that the problem is somewhere in the elestio setup.
I’ll confirm as soon as I was able to test.
To deacative / activate a single no you can use this turn off icon.
Or simple hit d on the keyboard when the node is focused.
An deactivated node is displayed lighter and (Deactivated) is added to the node title.
I asked because the node is deactivated on your shared workflow. :wink:
I feel SOOOOOO ashamed. What a noob-move !
I wondered at the start what the on/off symbol on each node ment. But as I never used it, I simply started to ignore it… but must have clicked on it accidentally for the MERGE node.
Then again: I wish all problems were so easily resolved :wink:
Thanks for the quick support !
