I found Merge
node can cause some branches be forced executed, even they have no input data.
Is this behavior as expected?
No
Please share the workflow
- n8n version: 0.201.0
- Database you’re using (default: SQLite): MySQL
- Running n8n with the execution process [own(default), main]: own
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: Self-Hosted
Thanks for any Reply~~
