Merge Node SQL Column Name the Same
Using Merge, two streams JSON in, combine with SQL. Select a field from input1 and UNION that with a field from input2. However, the result assumes the name of the first input, despite returning two.
    "A.field": "Trco8vHJq"
    "A.field": "Trco8vHJqiS9otZUUljHcDrIaJUEasPx+jzltSrbs+E="
The SQL statement can be simple or highly formatted, same result.
SELECT newstatementhash AS [A.field]
FROM input1 AS [A]
UNION
SELECT DocumentHash  AS [B.field]
FROM input2 AS [B]
Am I stupid, or is this a system problem?
N8N community - self hosted.
No database, just Merge node
N8N on Azure container
OS = Linux
Okay, I am the idiot. UNION… field names can’t be different.
