Our microsoft business oauth modules seem to repeatedly fail to get refresh tokens after a certain amount time. This is usually after about 1-2hrs although after a full workplace restart can sometimes be ok for 3-48hr
This happens even though the oauth is set to offline (scopes are: Calendars.Read Calendars.Read.Shared Calendars.ReadBasic Calendars.ReadWrite Calendars.ReadWrite.Shared Contacts.Read Contacts.Read.Shared Contacts.ReadWrite Contacts.ReadWrite.Shared email Mail.Read Mail.Read.Shared Mail.ReadBasic Mail.ReadBasic.Shared Mail.ReadWrite Mail.ReadWrite.Shared Mail.Send Mail.Send.Shared MailboxFolder.Read MailboxFolder.ReadWrite MailboxItem.Read MailboxSettings.Read MailboxSettings.ReadWrite offline_access openid profile User.Read)
The error comes through as a dummy.stack.replace is not a function error. Although this certainly seems to be an oauth issue. The issue did not use to exist, and seemed to be introduced for us at least on the 20th of Feb, so i believe a N8N release caused the problem.
The result of this bug is that our outlook related flows consistently fail and requires constant monitoring as only reconnecting the microsoft outlook oauth or restarting the workspace can resolve the issue.
I have even gone so far as to switch the oauth method from the built in n8n one to using my own custom azure Microsoft oauth app and the the issue is still persisting.
Problem in node ‘Get a message‘
- n8n version: [email protected] (although the bug has been present in the last 4-5 versions since mid-feb)
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Running n8n via (Docker, npm, n8n cloud, desktop app): cloud
- Operating system: NA
