yoan
January 12, 2025, 7:26pm
1
I don’t have Base URL parameter in my OpenAI Chat Model node, as I usually do to connect with OpenRouter API.
However it’s still set on other workflows where I’ve already used it.
n8n version: 1.73.1
Database (default: SQLite): postgres
n8n EXECUTIONS_PROCESS setting (default: own, main): default
Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
Operating system: Ubuntu
I have the same issue and found the open router base url was inserted here
But the model selection was not auto update so still having the same issue to use open router.
Had the same issue, currently you need to copy name and paste it to model field of AI you want to use from.
Example:
microsoft/phi-4
sao10k/l3.1-70b-hanami-x1
deepseek/deepseek-chat
Try to run workflow. I also had red trinagle, but when i ran actual workflow it worked
yoan
January 13, 2025, 10:02pm
6
Thank you guys, it works !
I did the following :
I changed the base URL in my credentials,
changed the model to ‘deepseek/deepseek-chat’
ran the workflow
system
Closed
January 20, 2025, 10:02pm
7
