Description
I have updated to the recent update of n8n from git repo, after running npm install in each package I tried running build.
However, got lerna ERR! npm run build exited 2 in ‘n8n-editor-ui’ with the following errors
Error message
These dependencies were not found:
* element-ui/lib/badge in ./node_modules/n8n-design-system/src/components/index.js
* element-ui/lib/button in ./node_modules/cache-loader/dist/cjs.js??ref--15-0!./node_modules/thread-loader/dist/cjs.js!./node_modules/babel-loader/li
b!./node_modules/ts-loader??ref--15-3!./node_modules/cache-loader/dist/cjs.js??ref--1-0!./node_modules/vue-loader/lib??vue-loader-options!./node_modu
les/n8n-design-system/src/components/N8nButton/Button.vue?vue&type=script&lang=ts&
* element-ui/lib/button-group in ./node_modules/n8n-design-system/src/components/index.js
* element-ui/lib/card in ./node_modules/n8n-design-system/src/components/index.js
* element-ui/lib/checkbox in ./node_modules/n8n-design-system/src/components/index.js
* element-ui/lib/col in ./node_modules/n8n-design-system/src/components/index.js
* element-ui/lib/color-picker in ./node_modules/n8n-design-system/src/components/index.js
* element-ui/lib/container in ./node_modules/n8n-design-system/src/components/index.js
* element-ui/lib/date-picker in ./node_modules/n8n-design-system/src/components/index.js
* element-ui/lib/dialog in ./node_modules/n8n-design-system/src/components/index.js
* element-ui/lib/drawer in ./node_modules/n8n-design-system/src/components/index.js
…the list goes on
#./node_modules/n8n-design-system/src/components/index.js
#packages/design-system/src/shims-element-ui.d.ts
n8n setup
- version:0.168.2
- Running n8n via desktop
- Running n8n with the execution process:
SET NODE_OPTIONS=–openssl-legacy-provider && lerna exec npm run build
