Missing parameter: \"code\" is required oAuth 2.0
Hi everyone, I’m not a developer, and I’m quite new to n8n.
When trying to create an oauth 2.0 for Moloni (Moloni Developers | Moloni API | Autenticação)
I’m getting this message: Missing parameter: "code" is required
I know the parameter I need is in the URL:
But I’m having trouble understanding where it should go on the configuration
Can anyone help?
hello @suardim
can you copy the code from the callback URL (first screen) and paste it into the second URL directly? (last part, your_authorization_code)
https://api.moloni.pt/v1/grant/?grant_type=authorization_code&client_id=[your_developer_id]&redirect_uri=[your_callback_url]&client_secret=[your_client_secret_code]&code=[your_authorization_code]
And what n8n version do you have? I don’t see that node in the n8n
I tried copying it.
But the authorization code keeps changing after each request.
my n8n is 0.233.1
Anyone can help?
The error is created during the code-exchange part of the oauth flow.
My theory is that this is some old bug in the oauth handler.
0.233.1 is a bit old now. We’ve rewritten quite a lot of the oauth2 related code since.
Can you please try using the latest version of n8n instead?
I need to migrate the whole thing.
But thanks, I will check if in the new n8n version the problem is solved.
After upgrading to the last version of n8n the problem persists.
Is there somewhere that I need to insert the code information?
Because the problem still looks like n8n doesn’t receive the code part for the oauth2, I’m having that problem with more than one service that requires oauth2.
Error: The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.
More details
{“error”:“invalid_request”,“error_description”:“Missing parameter: "code" is required”}
Failed to connect. The window can be closed now.
I still think that I am doing something wrong.
Is the source code for this credential available somewhere for us to debug?
I don’t think you would have the credentials needed
But the same happend with olx.
https://developer.olx.pt/en
It’s free to create an app.
let me know if I can help with that, or providing any other information.
It’s really something that’s bothering me
Is there anything else I can try?
