It would be really cool if the docs would show one example for the host URL.
hello @GutN8N
Can you elaborate on what you mean?
In the Magento module its unclearthat the user should actually only use the base URL of the shop.
In most API modules I was able to chhose the storeview for example, so its unclear which path extenstions are needed like:
/rest/de/V1/
But when I opned this I was not clear that the module has a hardcoded “/default/” ind the url path which was why I cant connect.
