I’m trying to create a connection to a Mongodb database, but I always get the error: connect ECONNREFUSED 127.0.0.1:27017, the strange thing is that in the connection string I’m not informing the host 127.0.0.1, but no matter how I inform it, I always get the same error, as if I always tried in the local host, this also happens when using the “Values” option.
I am sorry for the trouble. Can you check if the MongoDB connection is working in the regular node (outside of the credentials screen)? I wonder if this might be just a problem with the logic of the quick credentials check.
I just tested it, and the problem is not only with validation, the conventional use of node is also always trying the local host, ignoring the informed host.
