MongoDB Node Executed Successfully but No Output Data Returned N8N
N8N version:2.3.6 Community Edition
MongoDB NODE: V1.2
SAME ISSUE IS FACING ALSO IN N8N CLOUD SERVER
Need Expected output to return empty array [ ] when no resposne is coming from query
Hi @Amanpreet_Singh1,
From my experience most database related nodes work like this where if no records were found, the node ends the workflow with no output. The way to get around this is to enable the below setting, which will force the node to continue with an empty object
See this no output
Im not seeing your toggles? Did you enable the Always Output toggle?
Its not Displaying Its Hided what I see.
Its Solved but by again restarting the Container Now The Button Appears
